Bricksnbeatles
Member known well
Now this one is NSFW too
Well, as the OP, I consider that an achievement (even though I'm not the one responsible for the tag)Now this one is NSFW too![]()
Wear this badge of honor with pride my friend!Well, as the OP, I consider that an achievement (even though I'm not the one responsible for the tag)![]()
In other words, āno, it doesnāt affect the sound, but I refuse to admit it.I do not know but the answer I received was: āThe omissions from the power supply will decrease the headroom, slow down the transient response, and generally be significantly noisier.ā
I donāt know about thatā I read on the Steve Hoffman Forums about the profound impact a $25k iec cable for a hifi system really makes the top end sparkle, and really brings out the analog properties of some $300 45rpm āultradisc 1 stepā box set of some crummy SRV album or whateverIn other words, āno, it doesnāt affect the sound, but I refuse to admit it.
Hereās a bunch of magic word bullshit that doesnāt correlate with reality. Please donāt look into it any further.ā
Look, 18V is just *better* when it comes from a Rube Goldberg machine of rectifiers and regulators.The working voltages are similar and I think we can feel fairly confident the power supply rails aren't buckling under the heavy load of a single TL072 based clean buffer.
Yeah but what if you replaced the guitar with a 25Vpp sine wave from a function generator? Checkmate pedal nerdsThe working voltages are similar and I think we can feel fairly confident the power supply rails aren't buckling under the heavy load of a single TL072 based clean buffer.
"Okay now plug mains into it."View attachment 58556
... and it's still going to draw about 130mA less current ...
I supposed I could add an optional 2W 70 ohm resistor across the 9V line for those who want the full authentic experience.![]()
I've often seen brief 2v peaks on hot guitar/bass pickups when hit hard. Guitar straight to scope. Of course, just about any op amp buffer running off 9V should still handle them with ease. Especially one with R-R output.Let's say my bridge humbucker puts out about 0.4v on average and an op amp buffer is running just on 9v and biased at half that. Either side of the waveform would have to hit 4.5v to begin distorting, right? I don't think even hitting the strings hard would generate 1v at it's peak.
As usual, I am of the strong opinion that TL072 has no business being in a top notch guitar buffer in 2023. It's just too noisy at 18nV/sqrt(Hz) (same as the thermal noise of a 20k resistor). I would pick something with less than half that noise. And of course, it would also have to have very low current noise to do well with high impedance sources, so either JFET input or super beta bipolar (my new favorite). My best suggestions as a guitar buffer: OPA205/206/207, OPA145. Or, if you have all the money and want the quietest possible op amp that can handle high source Z, get an OPA827, or even two of them in parallel if you're nuts (I am, and I've done it).[...} single TL072 based clean buffer.
thatās a great quoteā¦Sufficiently advanced incompetence is indistinguishable from malice.
Tell me more... because I have a new DL4 mk2 and I hate it... Whenever I turn it on it adds an unwanted boost and a low mid thing... I have no clue how to make it stop, and I was so pissed at this brand new, $300 pedal that I threw it off my board and put my 20 year old original DL4 back on insteadHe has a very specific design philosophy about buffers. I think itās possible that, back in the day, tone suck from very long cables was a real pita and he certainly solved that problem with output buffers. To some extent I donāt think heās totally wrong: I have definitely experienced issues with modern built unbuffered pedals, things like the tone changes if you turn a delay (typically buffered) on after a drive which is caused by the drive having high output impedance and tone sucking when the delay is off and then the delay āfixingā that when on. That can cause serious problems for touring musicians, which is definitely the audience (Iām not one of them!).
The DL4mkII does have options for true-bypass and analog dry-through that might be worth tryingTell me more... because I have a new DL4 mk2 and I hate it... Whenever I turn it on it adds an unwanted boost and a low mid thing... I have no clue how to make it stop, and I was so pissed at this brand new, $300 pedal that I threw it off my board and put my 20 year old original DL4 back on instead
Looking at the specs sheet of the tl072 I also came to that conclusion when I first started looking into buffers (not that I had the knowledge to really make such an assertive claim to other people - I still don't hahah). What's you're opinion on the TLE2072?As usual, I am of the strong opinion that TL072 has no business being in a top notch guitar buffer in 2023. It's just too noisy at 18nV/sqrt(Hz) (same as the thermal noise of a 20k resistor). I would pick something with less than half that noise. And of course, it would also have to have very low current noise to do well with high impedance sources, so either JFET input or super beta bipolar (my new favorite). My best suggestions as a guitar buffer: OPA205/206/207, OPA145. Or, if you have all the money and want the quietest possible op amp that can handle high source Z, get an OPA827, or even two of them in parallel if you're nuts (I am, and I've done it).
TLE2072 looks like an easy drop-in upgrade over TL072, but I find it stupidly expensive for what it is. If you're going to spend 10x the price of a TL072, then might as well get a much better OPA2205. Only downside (for some) is that it's SMD-only. SMD is not hard, though. Just get the right tools and embrace the damn thing, else you'll get trapped in the past.What's you're opinion on the TLE2072?
