chongmagic
Here is what has been taking up my time lately.
Yep.Put them in your drill chuck and go slow
That looks perfect and you really need it! I use it everytime I power up an amp that I have worked on, even if it was just a minor modification. And also when testing second hand transformers or so, recently had it going white hot on a blown second hand power transformer and it showed it's usefullness...I went by Lowes and just decided to build one to have on hand.
It just ain't 9V DC you know....![]()
That is some clean work right there!I just twist the filament wires by hand. If you twist them with a drill you end up untwisting a bunch of twisted wire! I like to tuck the twisted bits right into the corner of the chassis. I also like to put the tube connections to the board underneath the board and up into the turret. You bend a little "V" into the end of the bare wire and it stays in the turret, especially if you have the insulated part go straight down onto the chassis so the wire can't fall out.
But that's just my anal retention rearing it's ugly head! Have fun - they're a great amp. This is a 50W I built - I love old school Marshalls!View attachment 4335
Sweet, Jon!
Sorry, didn't mean to hijack. I think you'll love the 18watter. It's worth taking your time with amp wiring because there is some scary voltage going on - turning an amp on for the first time always scares the begeezus outa me. I don't know if you've been warned, but sometimes when you turn an amp on for the first time it shrieks like a banshee. This can simply be that the output tranny is connected the wrong way around - all you have to do is swap the O/T leads over at the power tube sockets. They would be the brown and blue wires in your amp.
