If you look at how the pins in the sockets are held in place you can see that sometimes they will come out rather too easily. I've replaced pins in sockets a few times and bent the retaining bit a little more to help stop it from coming out again. There is a small section in the middle of the pin which is pushed out to make a kind of clip. you can push it out a little more and it holds in place a bit better. I think i used a pin or something. it's fiddly!
I like the pale brown Belton sockets for both octals and 9-pins. Just be careful when you splay the pins on the octals because they snap rather too easily. That's not a problem in your amp because it's all 9-pins, but believe me, if you like this amp it won't be the last you build.
BTW it is a good idea to splay the pins a little - ie bend them away from each other, especially on the power tubes, to help prevent arcing between pins. It also helps prevent them coming out with a tube.
