This Week on the Breadboard: Phase 90
Each stage shifts the phase between 0° and 180°, depending on freq and FET gate voltage. This is an LTSpice plot of the phase shift in one stage at various gate voltages. The green trace is -2.0V on the gate. The gate voltage is increased to -1.5V in 50mV steps for each successive trace.
There are four stages in series, so the total phase shift looks like this:
If the total phase shift at the output of the fourth stage is 180° or 540° (360+180), then the wet & dry signals cancel and we get a notch. If we divide 180° by four (four stages), we get 45°. Therefore, if the phase shift in each stage is 45° or 135°, then the total phase shift at the output of the fourth stage is 180° or 540°. Since there are two conditions that cause cancellation (180° or 540°), we get two notches. This is the output when the gate voltage is -1.9V.
Does that make sense?
I was under the impression that the phase shift was constant at the cutoff frequency. And that the jfet voltage controlled the cutoff frequency, giving the effect of the notch filter moving in frequency?
Now you know better.
Here is a plot of the notches for 11 different JFET gate voltages. It's a busy plot for sure. Pay close attention to the trace colors. There are two notches for each trace. A stock Phase 90 does not swing the gate voltage quite so far up and down.
It's very easy to switch between 2 and 4 stages. Robert did it on the XC Phase, take a look at the Build Docs. No LFO mods req'd. Bear in mind that with 2 stages, there is only one notch and the notch does not sweep as far up and down as it does with four stages. Here's the XC Phase set for two stages.
I think we are saying the same thing but in slightly different ways :) as the voltage changes the position of the notches changes as I expected.
More-or-less. The phase shift is constant with freq only at the extreme ends of the spectrum.
Yes, the gate voltage sweeping up and down moves the phase curves left & right which causes the notches to sweep up and down in freq.
The Joyo sounds like a Phase 45 until about 12 o’clock and the. Shifts to the more intense Phase 90 sound.
It’s a nice unit. Built like a brick shithouse with through hole stuff and the right JFETs.
Panasonic style caps and everything.
Very cool.
Latest & final schematic. I presently have 47nF caps for C2-C5 for the true Phase 90 tone. The Phase 90 is a great phaser in its own right. This is just my take on some tweaks to improve headroom and add some versatility. Do not go under 22K for R27 or the circuit will break into high-freq oscillations when RESONANCE is dimed.
Now, who’s gonna build it first?
I'm exploring one other tweak - the duty factor on the LFO. It's not exactly 50% in the Phase 90 or XC Phase because the LFO opamp doesn't clip symmetrically. When I replaced the zener with a 5Vreg, that affected the duty factor a little bit. What I'm trying to find out is does it matter?
