I was under the impression that the phase shift was constant at the cutoff frequency. And that the jfet voltage controlled the cutoff frequency, giving the effect of the notch filter moving in frequency?Each stage shifts the phase between 0° and 180°, depending on freq and FET gate voltage. This is an LTSpice plot of the phase shift in one stage at various gate voltages. The green trace is -2.0V on the gate. The gate voltage is increased to -1.5V in 50mV steps for each successive trace.
There are four stages in series, so the total phase shift looks like this:
If the total phase shift at the output of the fourth stage is 180° or 540° (360+180), then the wet & dry signals cancel and we get a notch. If we divide 180° by four (four stages), we get 45°. Therefore, if the phase shift in each stage is 45° or 135°, then the total phase shift at the output of the fourth stage is 180° or 540°. Since there are two conditions that cause cancellation (180° or 540°), we get two notches. This is the output when the gate voltage is -1.9V.
Does that make sense?
Now you know better.I was under the impression that the phase shift was constant at the cutoff frequency. And that the jfet voltage controlled the cutoff frequency, giving the effect of the notch filter moving in frequency?
Well, how bout that. Thank you sir.It's very easy to switch between 2 and 4 stages. Robert did it on the XC Phase, take a look at the Build Docs. No LFO mods req'd. Bear in mind that with 2 stages, there is only one notch and the notch does not sweep as far up and down as it does with four stages. Here's the XC Phase set for two stages.
I think we are saying the same thing but in slightly different waysNow you know better.
Here is a plot of the notches for 11 different JFET gate voltages. It's a busy plot for sure. Pay close attention to the trace colors. There are two notches for each trace. A stock Phase 90 does not swing the gate voltage quite so far up and down.
Seems that the original Script Phase 90 is the Gold Standard for phase shifters. And for good reason.I toyed with the idea of a DIY phaser for a while, but the MXR Script w/ LED Phase 90 is just perfect for me.
Blasphemy! There is always more phaser.I toyed with the idea of a DIY phaser for a while, but the MXR Script w/ LED Phase 90 is just perfect for me.
That’s what I hear, I need to check it out. Just a phase 90 clone? Among the dozens I’ve built is the BYOC classic phaser. I also built a 45 and 90 in one enclosure. It’s pretty cool for a phased tremolo type sound. One speed up and one speed about halfway.A really good sleeper phaser is the Joyo Vintage Phase.
Very cool.The Joyo sounds like a Phase 45 until about 12 o’clock and the. Shifts to the more intense Phase 90 sound.
It’s a nice unit. Built like a brick shithouse with through hole stuff and the right JFETs.
Panasonic style caps and everything.
Now, who’s gonna build it first?Latest & final schematic. I presently have 47nF caps for C2-C5 for the true Phase 90 tone. The Phase 90 is a great phaser in its own right. This is just my take on some tweaks to improve headroom and add some versatility. Do not go under 22K for R27 or the circuit will break into high-freq oscillations when RESONANCE is dimed.
