Brett
Most of the boards on PedalPCB are true to the original pedals, AFAIK. @Robert has traced a ton of them. Of course not all of them will be film only caps in the signal path. A designer may have needed 10µF for a particular purpose and using an electrolytic was more appropriate.I wonder - do the Pedal PCB boards limit polarized caps to non-signal positions?
If a PedalPCB board shows a polarized cap, that's most likely what was in the original circuit, but you'd have to confirm with the Robert.Seems like 2.2uf and up is all-polarized (silkscreen-wise) on any pcb I've seen so far...
