BuddytheReow
Breadboard Baker
The Two Sticks of Derm may be starting a design contest I have in mind.@BuddytheReow did a breadboard tutorial on the two sticks. I haven't tried it yet, but I smashed that bookmark button.
Do tell!The QM is a basically a 250 with a befuddling eq tacked on and two wasted op amp stages. I don’t think I’d recommend going that route—a better designed realization of that aim, sure, but not using the FSB trace schematic.
I built the quantum mystic on Vero according to the dirtbox layouts version. I like it for doom stuff but it needs to be driving something else. I use it with a rat mostlyThe QM is a basically a 250 with a befuddling eq tacked on and two wasted op amp stages. I don’t think I’d recommend going that route—a better designed realization of that aim, sure, but not using the FSB trace schematic.
Any more non-PPCB builds? I’ve exhausted most of the options from them. I’m also especially curious about clones of anything by Dunwich.
Is sleep not considered doom?Matt Pike used to use the Atomic Cock ( https://www.pedalpcb.com/product/pcb548/ ) but he may know nothing about doom
Doom demos?!…. Stand byDeadend FX Brass Monkey, (Devi Silver Rose clone) - Superfuzz and Opamp Muff in parallel, you can blend the two together and then there's tone, presence, and a clean blend after that.
Here's a taste on bass.
From Dunwich, I'd say the Wizard Fuzz might be your best bet.
Or the Fuzz Throne, Fuzzdog has that one.
Same guys, different Superfuzz! I'm partial to their version of the Last Gasp Arts Labs 46 SooperfuzzDeadend FX Brass Monkey, (Devi Silver Rose clone) - Superfuzz and Opamp Muff in parallel, you can blend the two together and then there's tone, presence, and a clean blend after that.
I got this one on my workbench right now. Waiting on a few parts to finish it up. Demos on YouTube sound awesomeSame guys, different Superfuzz! I'm partial to their version of the Last Gasp Arts Labs 46 Sooperfuzz
SHILLELAGH
The QM uses four op amp stages where only two are required:Do tell!
I don't know if the actual electronics layout sucks or no, but I do like my BAT pedal
I actually get better Mike Scheidt tones using a Bluesdriver and an EQ, though, come to think of it
Out of curiosity did you omit the tone-stack entirely or replace what would have been the TMB pots with resistors?Yeah haha, cheers! All credit to Chuck really, tho!
