benny_profane
@Robert Can we please get this pinned at the top of general questions.Measuring Vf at an arbitrary current tells us nothing about how that diode will perform in a given circuit.
Chuck’s post in particular. But indicating authorized vendors may be a good idea too. Mysticism about diodes and Vf seem to be a consistent misconception.The entire thread, or Chucks post?
Those things aren't worth it at any price, IMO. Not even stamped Central. Nothing at all, at least in my batch. Neither are the 88s.Yeah, not everything at Tayda is a deal. Compare the price of 2N5089.
Thanks for the detailed explanation! I stand corrected.If transistors are in-spec, then they will most likely work in the circuit. Some circuits need HFE to be in a certain range, either to get the biasing right or to control harmonic content. In the majority of Si circuits, whether the HFE is 100 or 500 doesn't matter. HFE is a measure of current gain. Most pedal circuits use BJTs as voltage amplifiers and voltage gain does not depend on HFE. Like Vf in a diode, HFE varies with current. There is no standard test current for HFE. The datasheets spec HFE at one or more collector currents and some datasheets plot how HFE varies with collector current. The transistor testers I've seen measure HFE at one collector current and it probably does not match the collector current in the pedal circuit.
For a particular wafer run, the specs of a given transistor are pretty tight because they were all made at the same time under the exact same conditions. Dozens or hundreds of wafer runs can be packaged on the same day and will have the same LDC. The only thing the LDC tells us is when & where the chip was put in the plastic package or metal can. Buy 100 2N5089s from Mouser and they will all have the same LDC. Buy 100 on Amazon, eBay, Tayda or Small Bear and you could end up with many LDCs. That is the cause of the variability.
HFE plays a minor role in a Silicon Fuzz Face. Q1 HFE mainly affects biasing. Q2 HFE affects tone. Either effect can be compensated by adjusting resistor values and/or adding a cap between base & collector on Q1 or Q2. Look at the Aldrin for an example of tuning the circuit to the transistors. Some (most?) pedal builders choose a particular part number based on price and availability. The EHX BMP is a prime example of this.
I only buy 5088s and 5089s from Mouser anymore. I have had too many problems with other suppliers.Buy 100 2N5089s from Mouser and they will all have the same LDC. Buy 100 on Amazon, eBay, Tayda or Small Bear and you could end up with many LDCs.
Sounds rad. Make a fun random noise deviceuntil it was putting out odd, noisy, atonal static.
I wish it was that kind of cool noiseSounds rad. Make a fun random noise device
Everything is cool noise if you amplify and distort it enough and run it thru a flangerI wish it was that kind of cool noise
Absolutely, and to also post explicit reviews about false products to protect the next customers - which could be one of us!Amazon does nothing to police their sellers. It's on us to demand refunds when we get cheated.
Is he Reputable?I ran into an issue with a fake TL072 on my last build. I didn’t realize they were fake, I bought them off Amazon and used them in a Muzzle noise gate. The gate would make a strange fizzle or crackling noise when the input signal would be close to the threshold. After posting about the issue, a kind individual pointed out that I had been had, and I was using a fake TL072. After I swapped the fake out the noise was gone. Going forward I am avoiding Amazon for ICs, and sticking with a reputable seller. I bought a handful off of Pedal PCB!
Wow. Very, very informative post, Chuck - thank you! I realize Ge may be a different story, but it's good to know that most Si circuits have a lot of leeway regarding hfe - the Fuzz Face being a slight outlier.If transistors are in-spec, then they will most likely work in the circuit. Some circuits need HFE to be in a certain range, either to get the biasing right or to control harmonic content. In the majority of Si circuits, whether the HFE is 100 or 500 doesn't matter. HFE is a measure of current gain. Most pedal circuits use BJTs as voltage amplifiers and voltage gain does not depend on HFE. Like Vf in a diode, HFE varies with current. There is no standard test current for HFE. The datasheets spec HFE at one or more collector currents and some datasheets plot how HFE varies with collector current. The transistor testers I've seen measure HFE at one collector current and it probably does not match the collector current in the pedal circuit.
Hmm. I was going to get just a few (real) 1N34A from Tubes N More, as they seem like a pretty reliable place that would test vintage components - although I've yet to order from them. I guess I didn't think about leakage being a factor in Ge diodes, just transistors. Makes sense that it would still be a consideration... Small risk, but it'd still stink to pay 2 bucks a pop for unusable diodes. I wonder if AES vets their 1N34As well. Not sure where else to go, really - or if it's even worth it compared to say, a BAT41.Germanium diodes is a whole 'nother discussion. They can be legit and still unusable.
Good question! Ha… I’ve seen them pop up in build docs for several fuzz pedals, but I think any Ge diode would do (unless it’s crap). They’re mostly in pairs, so it seems like BAT41 etc might sound about the same in that situation…Which circuit are you building that calls for 1N34A diodes?
