SOLVED King Nothing No Effect Signal
joelorigo
Hello all, I am getting bypass signal, but nothing when activated, including no LED. I saw a previous thread with the same problem so I have already followed some of the advice there. One thing to note is that I socketed C3 & C4 to experiment later with the bass response that was discussed in an earlier thread.
First, these continuity tests are all good. (I should note that the LED comes on D&E, normal?)
3PDT switch pins:
Pedal bypassed:
  • 1 -> 2
  • 4 -> 5
  • 7 -> 8
Pedal active:
  • 3 -> 2
  • 6 -> 5
  • 9 -> 8
Looking at the top row where it connects to the main PCB:
Pedal bypassed:
  • A -> F
  • B -> C
  • No continuity on other top pins
Pedal active:
  • A -> B
  • C -> D
  • E -> F
Pins C is ground and D is the LED cathode connection, and they correspond to switch pins 5 and 6 respectively.
Pin A is the input jack and F is the output jack. Pin B is the effect input.
Then, these voltage tests (using a 1.7A Godlyke Powerall 9v adaptor):
V+ pad, should be close to 9VDC (typically lower due to diode drop, but will depend on your power supply) - I get 9.17
cathode pad of D2. This is the high voltage rail, it should be 230VDC or so - I get 0, so obviously a problem there!
I am including a photo of the section of the DMM to make sure I was using the correct section.
Oh, actually the first thing I tried was a different tube.
I mean if you're still getting 0V on the cathode of the UF4007 we know we still have a problem with the SMPS. The circuit is not going to work until you get the high voltage rail sorted. Nothing is jumping out at me visually, but there has to be something somewhere going wrong. This could be a bad solder joint in the SMPS, it could be a short on the tube daughter board that's pulling the rail down, it's hard to say from the other side of a screen.
Just to be clear, SMPS = Switch Mode Power Supply, right?
And the SMPS is the whole Power Supply parts of the circuit?
I got 9.14 volts at the V+ pad and 0 at D2. Can you measure voltage readings from point to point, an equivalent to tracing the audio signal with a probe, to pinpoint where the issue is?
Is that on the cathode (end with the stripe) of D2?
You can trace power like that, but it's trickier with an SMPS because it's basically AC until it gets to the cathode of D2. So if your multimeter has an AC setting (or if you have an oscilloscope) you can check the anode end of D2 and see what's coming into it. The purpose of D2 in the SMPS is as a rectifier, converting the AC voltage from the FET into DC voltage. It needs to be an ultra-fast rectifier because the AC coming from the FET is significantly faster than 60Hz, and a generic rectifier diode like a 1N4007 can't keep up.
If you're not getting anything there, you can probe the gate of the MOSFET (connected to pin 3 of the NE555) to make sure the MOSFET is being switched. You should be seeing AC voltage there as well, but at a much lower level.
Yes that is where I was getting the 0 reading
I haven't ever used it yet, but it looks like it does!
OK
Thank you!
I put the UF4007 back in and put in a new IRF740. Still getting voltage on the V+ pad and still nothing at cathode of D2.
Switched my DMM to AC, and am not getting any thing on anode of D2 or pin 3 of the NE555. Actually depending on what range I have it on, it gives tiny numbers.
Tube was not installed during this.
Also, just checking, when checking these voltages, does it matter if the pedal is in bypass or active? I am getting these numbers both ways.
Out of curiosity, what do you have on the cathode side of D1? Also just for kicks, can you grab voltages of each pin of the NE555? Leave it installed, but VERY CAREFULLY poke each pin to see what you get.
