jimilee
This is what it does past about 7 o'clock. I still have distorted audio and this.
Changed all the caps. I’m telling you, this is a strange one.DC on the gain pot?
Leaky cap?
Heed the words of prophecy--an easy idea to test, anyway.That is 100% a bad charge pump IC4 - TC1044SCPA). Easy check is to remove IC4 (I socket all my ICs and transistors for this reason) and the pedal will then only be operating on your 9V supply and the square-wave oscillation will be gone.
Will do, I missed that part, thank you.Heed the words of prophecy--an easy idea to test, anyway.
Well I don't have that noise anymore. I don't have any noise anymore, so I grounded pin 4 of the ICs, that wasn't helpful either. Stuck a 7660 in there, same buzz noise. I appreciate everyone help, this is a real mystery.Heed the words of prophecy--an easy idea to test, anyway.
Are you saying the pedal has stopped working now?Well I don't have that noise anymore. I don't have any noise anymore, so I grounded pin 4 of the ICs, that wasn't helpful either. Stuck a 7660 in there, same buzz noise. I appreciate everyone help, this is a real mystery.
Yessir, with no charge pump, it has no sound.Are you saying the pedal has stopped working now?
Have you gone over every solder joint on the back of the PCB to make sure no stray joints or debris is present?Yessir, with no charge pump, it has no sound.
Several many times.Have you gone over every solder joint on the back of the PCB to make sure no stray joints or debris is present?
Ha ha ha, actually I have.Have you heard the saying '' When in doubt, give it a clout'' meaning have you tried tapping the pedal firmly on the floor to see if it gets worse or better?, keep you Amp volume low as it may Bang quite loud if there is a stray joint!
I believe they’re nichikon. I get them from stompbox parts.What brand of Electro Caps are you using?
You got it.3 pages in & no pictures of the PCB & Components, this needs another set of eyes!
Okie dokie. May be tomorrow. Thanks a tremendous amount.I'll be straight up & tell you, you have to clean that PCB before going any further!
Bend the Pots up and Clean & then I review again.
