Lead Solder Buzz
Ok, update. I removed the jumper. It did serve a purpose, it narrowed down the problem area to a hand full of parts. I replaced the 100P with a silver mica, no joy. I removed the 1uf, no buzz. I tried a non polarized and a tant 1 uf, got buzz. I connected the side of the 6k8 that originally connected to 1uf, to ground. Still no buzz. So as it stands no buzz with the 1uf removed. I’m getting correct gain control. What is the 1uf (c7) doing?
It’s part of the RC network making an active high pass filter. Similar to what’s going on with a RAT.
EDIT: it strikes me as odd that that would cause oscillation. You’re filtering out low frequencies (Fc=23Hz) and proving a path to ground for DC voltage so it’s not amplified.
Did you test to see if C7 + pad is going to Ground ?
The cap isn't oscillating. The mis match of the caps and resistors are causing the opamp to oscilate. See the link I posted to the ti article previously.
Could be stray capacitance in the pcb playing a part too.
I wonder if scaling the values and/or altering that part of the circuit layout would be a good idea.
Maybe even just rescaling the resistors in the feedback network would help.
Possibly. I’ll mess with it a little and look at changing some values.
Are you positive the toggle switch isn’t touching the bass pot legs? I know with mine it was touching and I saw it just before firing up. Made a fishpaper condom for the switch body so it didn’t touch the pot.
Not sure this is your problem but it’s cheap insurance form other issues.
Yessir. I have foam tape under it.
