I just posted a build report and quoted you in it. Did you build the PCB? I thought that it sounded quite cool.Just built a Zorkmid but it sounds a bit weird. Do we have a schematic or at least a pic of the PCB with values written on it so that I can check my work?
The ZorkmidJust built a Zorkmid but it sounds a bit weird. Do we have a schematic or at least a pic of the PCB with values written on it so that I can check my work?
 is a uniquely designed clean boost, overdrive and distortion pedal that offers a wide range of dirt tones while being very user friendly and easy to dial in.  It has BASS, MID, TREBLE, GAIN and VOLUME controls along with a 3-way CLIP switch and a 3-way CUT switch to make it work with a wide range of styles, guitars and amps.
  is a uniquely designed clean boost, overdrive and distortion pedal that offers a wide range of dirt tones while being very user friendly and easy to dial in.  It has BASS, MID, TREBLE, GAIN and VOLUME controls along with a 3-way CLIP switch and a 3-way CUT switch to make it work with a wide range of styles, guitars and amps.I set the treble to full as well. I mentioned in my build report that it’s on the dark side otherwise. It’s mentioned as a passive treble at the end so I think it only cutting treble? For me the tone control switch also doesn’t work to my liking, would prefer a treble increase instead of a treble roll off.So it sounds like the mids control is working as intended but overall it's lacking brightness. I seem to need the treble control pretty much on full, and that's with the cut switch in the middle setting. I just want to make sure I got all the right values in the right places. It's hard to check once the parts are in place. It may well be that it's working as intended. In that case I might want to change a few things!
That circuit adjusts the treble from -3dB@7khz down to -3dB@450hzI have to say that 10K on the Treble pot is a small window of adjustment???
R9 should be 3k3 Also change R10 to 3k3 to bring in some more highs at the expense of some bass boosting from the bass controlHey Harry - just read your write-up. Yup, that's pretty much how mine sounds. I would like a bit brighter sound! That's where a schematic would be handy. And yes, 10K for a Treble pot may seem to offer little adjustment but it depends entirely on the circuit and how it is integrated. I have a few ODs which use a C10K Treble pot and they work perfectly well. If it is designed well 10K can be all you need.
It's late here now. I'll give it another try tomorrow. Thanks guys!
Hi PaulR9 should be 3k3 Also change R10 to 3k3 to bring in some more highs at the expense of some bass boosting from the bass control
R10 is 4k7 now so I will try a 3k3 as well. I don’t mind a little less bass boosting as there’s plenty of that already.Hey Thanks Paul! I just tried a 3K3 at R10 and that's all I needed. Lovely! Much appreciated.
