It's all together, but it's my first build (of relatively few) that hasn't worked right out of the gates.
I had dry signal when bypassed.
No sound when engaged
No LED
I switched the LED leads, so the red wire goes to A and black to K, even though I had it red to square pad and black to circle pad like I've done previously (this time, I used the pre-wired LED from lovemyswitches--I guess they used opposite wire coloring?) (The diodes are added based on the stripes, the FET/saddle are aligned with the notch toward the top, and all of the electrolytic capacitors are positive side on top (in the square pad) and stripe on the bottom -- my one worry is if the LED was reverse what I'm used to, are the electrolytics reversed as well?)
I still have dry signal on bypass
LED works!
When LED is on, all I get is a hum.
I looked for solder bridges and ran a blade between everything.
I checked for ground faults (everything that beeped looks like it should have a ground connection, except I'm not positive the right-most pin on the A100K pot. This was the only pot pin to beep. The mini toggle didn't beep anywhere.) On the 3PDT breakout, GND always beeped, IN beeped when the LED is lit, and OUT beeped when the LED wasn't lit.
I'm not getting any ground continuity beep on the surface mount transistor leads to the breakout or pads (main board or breakout). I soldered it to the 5457 side of the board and connected left pad to left pad (D), middle to middle (s) and right to right (G) with the chip side up.
I checked wiring (seems good).
I'll order an audio probe, but any ideas on what else I can test?
No LED
LED works!
