Thanks dude, will do !!!Search for waterslide comments by @mkstewartesq - he's commented extensively on them and does a great job w/ his
Thanks. Not sure I can get it in the UK. I don’t understand why anyone would make water slide paper that dissolves in water. Think they missed the brief at R an D.I use Koala, I get it I. eBay. I had the disintegration issues until I switched to this. I tried a bunch of different ones, this works for me.
Cheers, like the price of gold in UKI’ve been pretty happy with Sunnyscopa Film Free.
it’s around $3 a sheet.You can fit 6 125b tops on one sheet so figure that in. It’s about $1.25 US a sheet in the US. What’s your cost? It has to be much cheaper than Tayda UV printing?
Thanks dudepretty much 99% of my builds get clear waterslide...sunnyscopia for inkjet.... print.... spray a light coat of clear gloss " Lacquer".. let dry 10 minutes.. then hit it with a wet coat of lacquer.... dry several hours.... trim out the decal..... i soak the decal in warm water for about 5-10 seconds.. place on the counter and watch the paper lay down flat... when you first take it out its curled.. once it relaxes its ready to apply.... lightly wet your enclosure.... I push up the decal on its paper to expose about a 1/4"... slap that edge down on the enclosre and line up... then i lightly pull the paper out between the decal and the enclosure......
Is this the one you use? I have been using Sunnycopa but that seems to be expensive and harder to get lately.I use Koala, I get it I. eBay. I had the disintegration issues until I switched to this. I tried a bunch of different ones, this works for me.
Yessir, but white instead of clear. The colors stand out better.Is this the one you use? I have been using Sunnycopa but that seems to be expensive and harder to get lately.
https://www.amazon.com/Waterslide-Transfer-Sheets-Printable-Printer/dp/B0BRCRH765/ref=sr_1_5?crid=2PBYET73QU5MT&dib=eyJ2IjoiMSJ9.MZ-bse1wP3R6TyUwcCIhfKCdDA1dJwxN1GbM1_HGkp-JKM8-xQB7-L4tafwXbhE1HQdGI4Ya_XWf43r2i12fdWEij0YBe4GoG-bvzPHXBVZySjj3tOZQHwNBbFEHtzSKSh1ezj6xm3gAnz0DaYTiTuofPhU6u4vzHf4atb4RD9tPkwVjsIeAIXxc5xwSUtFH4f98Oc3O4W5k-okMdX6lBkxv_nn38paihtRQP032piIdDMYGk0WV42FKfaRDUEIojMaqEW_3cma7GZBWNH74iF4lRB5D1waWj3fEkGduU4A.zWdbJfWHg1GLNDp7DsbLJNyDLjqwyr_h3lk4ox7IlYg&dib_tag=se&keywords=koala+waterslide+decal+paper+laser&qid=1773156598&sprefix=koala+waterslide+decal+paper+laser,aps,218&sr=8-5&th=1
Thanks. Yes, I have used white Sunnycopa also.Yessir, but white instead of clear. The colors stand out better.
Yep. Laser printers are becoming more affordable.Thanks. Yes, I have used white Sunnycopa also.
Do you print at home? I have been going to Kinkos / FedEx but that has been becoming more problematic over time also.
