Op-amp Big Muff JHS Pumpkin Patch Mod
classic.evil
Hey there, does someone has details about the Pumpkin Patch mods JHS did with the Op-amp Big Muff?
Thank you!
Try futzing with R11(in this schem)
It will misbias the 741 stage. Try omitting it completely and a 1meg pot wired as a variable resistor in series with say a 250k resistor. Find cumulative resistance values that work.
You'll basically add more/less DC offset to the AC signal, forcing it into one rail. Once the AC signal is operating only on one side of the bias, you should get a gating effect as it just looks like DC at that point.
I think. It's early
Can you see the value on that 9mm pot?
I have a stock one I can trace for a schematic.
That’s the only marking I can see other than the alpha logo on back. I tried to get the knob off just now so I could take the pot out but half the flat head screw insert broke off🤣.
Yeah, I think it's the AMZ presence control. In the case of the attached schematic R15 us replaced by a 3k3 resistor and a 25k pot
This guy. Josh, just say im doing the amz tone mod. All the people will still have you do it who dint know what it is anyways.
