What’s on *YOUR* workbench?
Aww yea big boyz came in today.
I was not intending this to be an actual burn-through on this run, just a cut of the paper. It's definitely progress, though.
Alright, so update on this. I tried very minor increments of power—two passes (cross-hatch) at a constant speed of 1500 mm/m and power increments of 2.5% from 20-35%— and I cannot for the life of me get it to only burn the paper… it either removes only part of the paper, or it starts to burn into the finish. So, !@#$ it, let's burn through part or all of it and PAINT over it! Seriously, from 20 to 22.5% and it goes from piddle to BURNINATION.
Letting the paint cure for a bit before I re-coat. Also doesn't help that my all of my white or off-white rattle cans have gone tango uniform. Interestingly, the cheapo no-name stuff was still usable while the Krylon was utterly worthless. I Think I have some Rustoleum in yellow that's pretty bright…
I dunno, there might be another way, but that's where I am. I guess there's """"benefits"""" to having a $4k CO2 or fiber laser over a hobby 5W diode :p
Finally found a second one of my beloved antique bakelite table fan. This one's to be used as a guide to rewind the coils of the motor in my burned unit (these weren't made for today's tropical heatwaves... 😅). Went for a visit at specialized company that fixes these for industrial applications. It's a four hour job by a professional (160,-), so he suggested finding a hobbyist. Impossible to find, I learned! So I am going to figure out through Youtube on how all of this works. Already found the right laquered copper wire... 11,5km of 0,056mm on a spool. Insane.
But this is going to be an absolute pain in the ass, I'm afraid.
Below is the emptied fan that needs fixing. The bakelite is really amazing on these. And ofcourse, that aged copper. <3
progress is progress…
I went over a previously etched area, causing a bit of leakage (new tape applied so I had a hard time seeing it…). Also used crappy paint on the first coats, and no primer. Think I need to a) do a second outline cut. Since it's a nice fluid motion it should clean up the edges. I wonder, too, if the textured finish of the powder coat is also contributing to the bleed.
What am I exactly looking at here? You make it eat through paint?
So a scrap "lid" from a powder coated enclosure is the test surface. I've been testing ways of using paper based tape (for vinyl cut transferring) as a paint mask, since it's lower tack than making tape it comes off easier. Using my laser engraver to do the job, it's proved difficult. So these are just tests.
I've been thinking that even though I'm using low power, I might need to play with the settings more: something that is so low power that it will etch away the paper, but not the powder coating.
Worst case scenario, I just fill in the etched away material with paint, sand, and poly coat it. Or I just make enclosure art with my crappy hand lettering
I wonder if instead of spray paint, using a liquid paint and something to spread it in a squeegee type motion(ala silkscreening) would work? At least it would leave less paint behind that needs to be removed. It may even slightly recess the paint left behind?
0000 or 000 steel wool may do a better job of grabbing some of the bleed as well?
One could employ mixes or paint to get some cool effects as well.
If pondered trying this on some etches myself but haven't gotten around to it.
A smooth texture powder coat, or even a painted and sanded one, could be beneficial. Less crevices. Again, 0000 to be gentle.
Not sure how well the laser handle paint. Imagine lighter paint would burn/discolor. But high temp paint may not. Not grill paint but engine/caliper paint. But that stuff comes with a price tag. I stop by audio stores sometimes on errands. You can occasionally pick up a few cans of auto paint on random clearance.
Another thought is maybe, of even possible, is to make each pass a micron smaller than the previous. Thought being that it tapers the "etch" in a slope.
Of course I'm a bafoon talking out my blowhole but enjoy the ride and seeing your progress.
How hot does the enclosure get, if at all?
If the laser could burn away paraffin, maybe a thin paraffin coating applied before the laser "etch" could act as a mask post "etch"? That would probably just make a mess though and cause adhesion issues where you want adhesion. All goes back to a smooth starting surface...
hopefully this is the one.
that's a beaut of a loaf, sir.
I'll admit I felt kinda dumb for not understanding this exact thing you mentioned in a PM 🤣 but I think I get what you're saying. Won't matter if the top gets sanded/touched if I'm poly coating it anyway. I was getting hung up on the steel wool.
Screen print squeegee approach is worth a test. Only concern is the counter spaces of the letters coming off. But nothing ventured nothing gained.
I did something similar with just primer and a few coats of green paint and they're wasn't any burning even without a mask. I just think the mask would go one step beyond.
That's a single pass, no hatching. Definitely suffers, but an outline pass would kick it up a bit.
It doesn't get hot in the tests, and it's been s while since I tried a whole enclosure, so I couldn't say if it's really causing enough heat to foul anything. I'd say it's kind of a non issue unless I'm at 100% power moving at <400 mm/m
I found the best method to just be getting your settings right so it just burns black on most powdercoats, then seal the burn with some clear coat. Paint filling is a fools errand. Trust me, I'm a fool. :ROFLMAO:
I've had this board for a year and I think I will finally tackle it this week. One second analog delay with "stereo" output. I know the design is good (I always say that and I'm right maybe 40% of the time) but I bet I made a mistake somewhere. Actually, I already know of one but it's small.
