Alright, so update on this. I tried very minor increments of power—two passes (cross-hatch) at a constant speed of 1500 mm/m and power increments of 2.5% from 20-35%— and I cannot for the life of me get it to only burn the paper… it either removes only part of the paper, or it starts to burn into the finish. So, !@#$ it, let's burn through part or all of it and PAINT over it! Seriously, from 20 to 22.5% and it goes from piddle to BURNINATION.I was not intending this to be an actual burn-through on this run, just a cut of the paper. It's definitely progress, though.
What am I exactly looking at here? You make it eat through paint?progress is progress…
I went over a previously etched area, causing a bit of leakage (new tape applied so I had a hard time seeing it…). Also used crappy paint on the first coats, and no primer. Think I need to a) do a second outline cut. Since it's a nice fluid motion it should clean up the edges. I wonder, too, if the textured finish of the powder coat is also contributing to the bleed.
So a scrap "lid" from a powder coated enclosure is the test surface. I've been testing ways of using paper based tape (for vinyl cut transferring) as a paint mask, since it's lower tack than making tape it comes off easier. Using my laser engraver to do the job, it's proved difficult. So these are just tests.What am I exactly looking at here?
Mmmm… is that going to be in the what’s for dinner thread later?Take number 137. There is an exact science to making sour dough. I didn’t know that when I first started. Just took it out of the oven, hopefully this is the one.
What flour mix are you using? How long did you bake it for? It’s pretty nice looking!Take number 137. There is an exact science to making sour dough. I didn’t know that when I first started. Just took it out of the oven, hopefully this is the one.
Jimi, I'm coming over right now. Leave the front door unlocked, I'm barging in!Take number 137. There is an exact science to making sour dough. I didn’t know that when I first started. Just took it out of the oven, hopefully this is the one.
that's a beaut of a loaf, sir.hopefully this is the one.
I'll admit I felt kinda dumb for not understanding this exact thing you mentioned in a PMI wonder if instead of spray paint, using a liquid paint and something to spread it in a squeegee type motion(ala silkscreening) would work? At least it would leave less paint behind that needs to be removed. It may even slightly recess the paint left behind?
0000 or 000 steel wool may do a better job of grabbing some of the bleed as well?
One could employ mixes or paint to get some cool effects as well.
If pondered trying this on some etches myself but haven't gotten around to it.
A smooth texture powder coat, or even a painted and sanded one, could be beneficial. Less crevices. Again, 0000 to be gentle.
Not sure how well the laser handle paint. Imagine lighter paint would burn/discolor. But high temp paint may not. Not grill paint but engine/caliper paint. But that stuff comes with a price tag. I stop by audio stores sometimes on errands. You can occasionally pick up a few cans of auto paint on random clearance.
Another thought is maybe, of even possible, is to make each pass a micron smaller than the previous. Thought being that it tapers the "etch" in a slope.
Of course I'm a bafoon talking out my blowhole but enjoy the ride and seeing your progress.
How hot does the enclosure get, if at all?
If the laser could burn away paraffin, maybe a thin paraffin coating applied before the laser "etch" could act as a mask post "etch"? That would probably just make a mess though and cause adhesion issues where you want adhesion. All goes back to a smooth starting surface...
I used an AP flour recipe. 450 for 30 covered and 30 uncovered.What flour mix are you using? How long did you bake it for? It’s pretty nice looking!
Actually, I already know of one but it's small.
Backwards regulator?
