I think we're getting close. The only missing piece is a tag board to split AC1 and AC2. 2 lines to the DC mod pcb holes and 2 lines to the other v3, v4, v5, v6, etc.I ran AC1 and AC2 to the lamp and then took a feed from there for the heaters. For both pre and power tubes.
I’m guessing (and it’s only a guess!) That you would use AC1 and AC2 for the 6L6 and 12ax7 V3,V4 and V5, and then run the DC heater to the 12AX7 V1 and V2?? Proceeded with care
Most DC heaters I have seen have been running the pre-amp tubes only. So this might actually make sense.
I see you grounded your heater wires at the pilot light. Is there a particular reason for the location? There is a lot of room so I can see why you might.Different pic.
That's what I figured. I didn't see it in the pictures though. So you actually have 6 wires from the pilot. 2 to pre, 2 to power and 2 to the board, yes?I did. That’s the Faux ground I needed. Kept it all neat. And no need for another bit of strip. I have also seen them done near the IEC too.
I ran a wire from the pre amp tubes down to the power tubes. I think you could do both though. One pair to the pre and one pair to the power.
I took a twisted wire from V5 under the board. To V7 and V8.
Great work! Looks fantastic. That’s some dead straight wiring. Makes me want to re-do some of mineGreat work. You're correct that in the past year a lot of people built SLOs, I was one of them! Here's mine, the PCB was from Sirius Amplification in Australia. I absolutely love mine, probably my favorite amp of all time, I see why basically every high gain amp created after it was based on it! Cheers.
Nah, yours is awesome!! I get solid wire straight like that by gripping one end with pliers and twisting the other end in a drill. Only a bit!Great work! Looks fantastic. That’s some dead straight wiring. Makes me want to re-do some of mine
Almost done. Still haven't decided on DC heaters and/or elevated heaters
Great stuff Andrea !Hello guys!
this is Andrea from AA Electronics (maker of these PCBs).
Great job on the SLO! Looks great, really like how clean it came out!
For anyone interested, I’m currently running a discount on all boards (20% off with code NEWYEARPCB).
Here’s a link to my website if you want to know more: http://aaelectronicspcb.com/
Cheers from London
Andrea
