I think we're getting close. The only missing piece is a tag board to split AC1 and AC2. 2 lines to the DC mod pcb holes and 2 lines to the other v3, v4, v5, v6, etc.I ran AC1 and AC2 to the lamp and then took a feed from there for the heaters. For both pre and power tubes.
I’m guessing (and it’s only a guess!) That you would use AC1 and AC2 for the 6L6 and 12ax7 V3,V4 and V5, and then run the DC heater to the 12AX7 V1 and V2?? Proceeded with care
Most DC heaters I have seen have been running the pre-amp tubes only. So this might actually make sense.
I see you grounded your heater wires at the pilot light. Is there a particular reason for the location? There is a lot of room so I can see why you might.Different pic.
That's what I figured. I didn't see it in the pictures though. So you actually have 6 wires from the pilot. 2 to pre, 2 to power and 2 to the board, yes?I did. That’s the Faux ground I needed. Kept it all neat. And no need for another bit of strip. I have also seen them done near the IEC too.
I ran a wire from the pre amp tubes down to the power tubes. I think you could do both though. One pair to the pre and one pair to the power.
I took a twisted wire from V5 under the board. To V7 and V8.
