drgonzo1969
Does anyone have a tayda drill template for the PedalPCB 4 Tap DC Converter/Isolator 1590A?
https://drill.taydakits.com/box-designs/new
Hell yeah! Thanks for posting thatLooking back at it with fresh eyes this morning... 1mm too far apart. That one was drilled at 22mm distance and I already adjusted my drill template to 21mm but have not tested it yet...holes could be a little smaller if I was certain about the placement.
Anyway, here it is : https://drill.taydakits.com/box-designs/new?public_key=SXBFVGhsTUpSaFh6d1MzUjN1ZDNyUT09Cg==
EDIT : Hole size is good as is.
That’s a very interesting idea. I bought two but I hadn’t thought of boxing them togetherI've DYI'ed a similar concept for a 125B type enclosure. 18vDC 1.5A input supply, a 9vDC (LM317T) regulator trimmed to 9v and filtered, (5) 9vDC isolated outputs and (2) 18vDC inputs.
If i can fit this with Terro board, PedalPCB can surely fit it with their double sided layiouts!
anasounds.com
I have a 24V 6A power brick and am tempted to build a bigger power supply based on the old Anasounds files...
Any eta on the isolated dc board restock?I really like that modular design...![]()
Just received one drilled at a 21 mm spacing ... it's still not perfect, they are a bit too close now. Maybe a 21.5mm spacing would place them in the right spot.Hell yeah! Thanks for posting that
i also need this.Hi, does anyone have a printable drill template for the 4 tap dc brick?
