Fuzzy Fox Midrange Mod
VanWhy
I am curious about adding the midrange mod to the PPCB Fuzzy Fox board. Aion FX includes this on their Vulcan board, so I'd like to transpose this on the PPCB version.
There is no schematic for the PPCB Fuzzy Fox. Below is the Aion schematic with the midrange switch cropped out.
Can someone show me how to implement this?
On the Fuzzy Fox build I do see a 3N3. I'm assuming that's the cap. (Again, no schematic so just assuming).
I've done the diodes on a switch but never caps yet. Is it the same? How do you know where to connect the center lugs of the toggle switch to the PCB?
Can't draw anything at the moment so I'll try to describe.... 😵‍💫
The 3n3 just below the tone control is the equivalent to C10 in the schematic above.
I'd install the cap in the PCB like normal, then connect a wire from the left pad (of the 3n3) to the center lug of an SPDT ON/OFF/ON toggle switch.
One side of a 5n6 to one outer lug of the toggle, one side of a 15n to the opposite outer lug of the toggle.
Connect the free ends of the 5n6 and 15n to the right pad (of the 3n3) on the PCB.
Perfect, thanks! Exactly what I was looking. You explained it so no drawing needed. Much appreciated.
Thread is Switch-Craft, but start at post #34, that's where the cap-talk starts.
PauloB's post #34)...
dpdt-on-on-on-switch-3-component-option-switching-jpg.98044
AceHyzer's fantastic find:
1751078393620-png.98050
Cybercow's cool contribution:
3-way_toggle_on-on-on_for_ordered_cap_switching_diagram-png.98088
Another method from me (based on my meandering perambulations across the Internet):
dpdt-on-on-on-acts-like-3pdt-cap-resistor-png.98101
So for the immediately above: you'd wire up from the leading PCB-pad of whatever component you're replacing to lug2 of the DPDT on-on-on (111) and then each component wired to their respective lug (Component 1, 2, 3) and then wire up all the leftover leads together and run a wire from those 3 leads "braided" together to the trailing component pad on the PCB.
No time to fire up a diagram right now, I'm in the middle of finishing a build.
If requested, I'll do one up later (while summoned, I haven't actually looked at what this is for).
Also Aion has a great example of getting a Muff tone stack to sit in the correct order of BUMPED / FLAT / SCOOPED.
