Whaa? You’re gonna have to explain this one to the mint-flavored paste kidView attachment 91008
FOR THOSE TIMES YOUR TOGGLE NEEDS VISUAL-AUGMENTATION BY LEDs
It's for someone who wanted LED indication for each position of a SPDT on-off-on switch.Whaa? You’re gonna have to explain this one to the mint-flavored paste kid
Toggle Down = top row connected to common, RED & BLUE (gives you magenta)
Toggle Centre = no connection for SW-1, BLUE ONLY
Toggle Up = bottom row connected to common, GREEN & BLUE (gives you cyan)
NOTE the JUMPERS; also, there are different kinds of on-on-on configurations, so make sure you know which configuration your middle position is when ordering 4PDT on-on-on switches. Read the datasheet(s)!
That gives you 3 different colours, one for each position of SW-1. You could stick any of the three colours in the middle position, for instance if you wanted a YELLOW light, you'd combine RED & GREEN.
Since the individual colours on the RGB-LED each have a different forward voltage from their neighbouring colours, it would be best to breadboard the switch to determine what value each CLR needs to be for an even brightness (if so desired!) and colour mixed to taste.
Here's a quick 1-minute primer on colour-mixing with light:
Now I get it. I looked at “SW-1” and saw an actual switch rather than solder pads. And hadn’t even thought about magneto or ryan, so double thanks.View attachment 91008
[EDIT]
Explanation of the situation:
To get LED indication for an SPDT on-OFF-on toggle (ALL THREE POSITIONS), I had to resort to a 4PDT on-ON-on toggle.
You say: "Why not just look at the position of the BAT?"
Well on a darkened stage away from your pedalboard, you can just look over at it and SEE THE LIGHT, but not the BAT, man. Woah Man!
The left-most 2 poles operate as per the SPST on-off-on. The middle position is off, nothing connected.
The right 2 poles are for manipulating the RGB-LED, getting a colour for even the "OFF" position of the switch.
To reiterate from its original posting:
Toggle Down = top row connected to common, RED & BLUE (gives you magenta)Toggle Centre = no connection for SW-1, BLUE ONLYToggle Up = bottom row connected to common, GREEN & BLUE (gives you cyan)
NOTE JUMPERS placement.
Make sure you get the right type of 4PDT on-on-on — DPDT equivalent is a TYPE 2. Read the datasheet(s)!
You can mix up the order of colours to taste, and achieve different hues with different CLR value, juggling their values to achieve the desired colour AND brightness.
*** IGNORE R12, that's just there as a reference point from the original circuit this lit-switch was intended for.
R12's NOT PART OF THE SWITCH(ING)!
Use the 4PDT switchery, minus R12, for any situation you want to replace the SPDT on-off-on for same functionality with LED indication.
IF ANYONE HAS A BETTER WAY OF GETTING LED-INDICATION IN THE "OFF" POSITION, PLEASE POST IT IN THIS THREAD!
Here’s a spin on that, using a 4th pole to ground the inactive side.No SWITCH-CRAFT here, just a bog-standard A/B Loops selector with master bypass.![]()
Cool, it's actually pretty simple.
You'd wire your switch as follows:
Pay close attention to the tags, the I/Os for the effects are re-ordered compared to the previous images. Switch pins are labeled in the schematic.
You could optionally add an indication to the switch setting by going with a 3PDT as follows:
You don't even have to remove the LEVEL pot from your build.
Just add the wires and DPDT as shown to go from the LEVEL-pot setting to FULL-BLAST.
If you need to tame full-blast just a smidge, you can stick a resistor inline between the pot and the switch, either
SW LUG-2 <> LEVEL-3
or
SW LUG-1 <> LEVEL-2.
I recently was looking at the octaking octave fuzz schematic and I appreciated the smart use of switching to achieve a logical layoutA DPDT on-off-on switch is often used for a three position filter switch, with two alternative capacitors across the end pairs of terminals.
The problem with this is that the layout of the options on the switch is illogical, with the minimum or maximum value on the middle position of the switch.
So here's an better alternative using a DPDT on-on-on switch that allows three alternative component options (or two components and a wire-link or open circuit) to be laid out on the switch in any order.
This seems very useful to me, but I couldn't find a diagram for it on the web, so had to work it out for myself.View attachment 98044
I love this thread! Of all the pedalometry I’ve managed to learn myself over the years, I still can’t hardly get my head around multi-pole switches. I think I have switchlexia
