Erik S
Was chatting with @giovanni about enclosure drilling over on the workbench thread, and I mentioned how I like to drill with a little alcohol in order to try and reduce the heat at the cutting edge, and try and reduce the amount of aluminum the builds up on the cutting edge of the drill.
I just finished drilling 258 holes all with the same step drill then took a look at the cutting edges.
Getting a phone shot through the microscope is tough, but here's one with a little aluminum booger on the edge, and then after I scraped it back off.
If your step bit seems like it's dull, it might just have aluminum built up on the cutting edges. If you can get it off without messing up the edge it should cut like new again.
Regarding the efficacy of the alcohol, I had no build up on the tip of the tool, and really only significant boogers on the steps where I pause to chamfer the common hole sizes. At that point I think the alcohol at the edge has largely evaporated or gone down the hole, so it's less effective at that point. Not totally scientific, but I'm going to keep doing it.
Looking close I realize my before/ after shots may not be the exact same edge, but you get the idea.
