Is the Main Out/Volume switch (next to the volume knob) on?
This is a weird switch that most synths don’t have.
You’re right that the A440 should give you a drone even without MIDI hooked up.
I assume you tried the outputs on the back as well as the ones on the front panel?
Is this one new or used?
Don’t do that to me
The A440 should bypass all of those controls though, so if he’s not getting sound out of it…Did you turn up the LPF?
I did the same thing when I got mine
Also turn the oscillators up and on.
The A440 should bypass all of those controls though, so if he’s not getting sound out of it…![]()
