[Edit: trying to wrap my head around the schematic and making too many conclusions too quickly]Looking at the schematic there: it's gonna depend on a couple of things.
Keep in mind, I'm just exercising some very rudimentary knowledge about filters and such so I could be way off here.
The biggest impact will be in mode A, especially if you use one of your throws to make an open circuit. That might get ya in an area where you start to hear a difference.
I'd leave the connection open, no jumper. That 1nf cap in parallel is there to carry the signal through and block any DC from the previous stage.AHA! So, in the actual amps, I believe it was only the Matamp that had the rotary switch.
I think maybe then the FAC only applies to "Mode A," AKA the Matamp section. Right?
I had suspected this before, but maybe mistook the switch position for the Orange/Matamp sections. I thought Orange was switch left, Matamp switch right. Obviously I tried both and the issue still stands that the tone difference is so subtle I have trouble knowing if the cap switch is being applied or not. I will try no cap/jumper and see what happens.
BTW, I did not choose any of the components nor the rotary, they were all supplied by Musikding.
So with the first cap lifted, the rotary does make somewhat of an audible difference in the bass frequencies (dimed bass and then treble pot to test), but not that much cap to cap, with the A/B selector switch to the left, which I assume (maybe incorrectly) is "switch A". In switch B mode, it makes much less of a difference. It's basically only audible in the distortion harmonics/"tails" when you let the note ring out. Like a very subtle filter.I'd leave the connection open, no jumper. That 1nf cap in parallel is there to carry the signal through and block any DC from the previous stage.
It's difficult for me to make heads or tails of how that rotary switch will impact mode B: lots going on there. It's still going to do *something*, but I couldn't tell you if it'll be audible or not.
*Wipes sweat from brow*Orange OR120 is Gain Stage > Tone Stack > Gain Stage > FAC > Gain Stage.
Matamp GT120 is Gain Stage > FAC > Gain Stage > Tone Stack > Gain Stage.
The Tone Stack and FAC positions are swapped in the two amps and the pedal mode switch emulates this by disconnecting ground in one of the tone stacks.
The pedals FAC position doesn’t change based on mode (like in the actual amps) but, arguably, having it in the GT120 position has a bigger impact. @Stickman393 is correct, it lets more bass into the gain stages. Do you have a bass-heavy guitar or a bass to try?
Edit… More on the FAC here:
Took out C7 and socketed a 470pf, and started rebuilding the rotary along stickman's suggestions, but....Orange OR120 is Gain Stage > Tone Stack > Gain Stage > FAC > Gain Stage.
