I don't see a depth switch on the panel of a fireball anyways.
Only on the 60 and 100, not the little 25.
These two don't seem to be using any protection.
Responsible pedal chaperones will keep a minimum distance between pedals' jacks with appropriate patch cables and will ensure there's a buffer somewhere in the chain.
Somebody lets un-buffered pedals couple like that depicted, then that player deserves the resulting inundation of 1590As...
Just sayin' ...
Practice safely.
I've been using smd jfets more recently and have been soldering them as one of the last steps while populating the board. I know some components are sensitive to heat (IC chips/transistors), but is it okay to solder the smd jfets as a first step, before there are components in the way of the soldering iron?
I have smd>to92 boards which I use sometimes if I'm jfet rolling, but have a decent stash of loose jfet smds. I have no issue soldering them (especially since I bought a fine needle-tip angled tweezers) and I'm also not a dufus burning the board. Just wondering if soldering the rest of the components after I solder the smd jfets first would cause an issue?
I solder the smd parts to the board first. Never had an issue (except for that one time where the FET was fake and then I lifted a trace trying to swap it out), but I never even considered that it may be putting a lot of heat on the lil guys.
As opposed to the natural ring of the note it is basically a dead thud which I guess would mean the compressor is really clamping down on an extra hot signal, but that is even with the ratio at ab 9 o’clock or lower. The active signal def drives the Thumbsucker into distortion if the threshold is low.
A liltle late to reply, but wanted to add to...
What JTEX said in post #339: use a HPF (something I think every bass player should have right after tuner, in terms of importance).
Also, you could add a pot to your Thumbsucker, between the jack and the circuit-input, to attenuate the signal from your Ray's Active-Pre. You could even put the pot on a toggle or stomper to bypass it when you're playing a bass without a preamp (or switched off your Ray's Pre).
Of course, lowering your bass's volume whenever you engage the ET works in place of the added pot, and doesn't cost you anything extra — if your bass has a volume sweet-spot, then the added pot on the ET-build may still be worthwhile.
Has anybody made the Engineer's Thumb with a side-chain?
Might be worth looking into.
Or DIY your own multi-comp — split the signal and compress the highs and lows separately; start messing with crossovers... I might have to go over to TalkBass and pick FEA's Frank Appleton's brain...
@Robert right on, that's gonna save me a ton of headaches, like this one. Noice!
At this point, I'd definitely use an adapter-board for that 2N5457...
I think soldering rework is more likely to toast a part. The initial placement is usually forgiving.
Are the weird resistor values from dead end fx based on the actuall values the dmm showed while tracing (including the tolerance) or are the makers of the circuits (noticed that for spaceman fx) able to hear a pin drop?
I recall hearing at some point that Spaceman Effects chooses resistor values based on part on the color scheme - they have some kind of aesthetic in mind for the inside of the pedals.
Something I want to know but it's probably dumb; What does FAC stand for? In reference to rotary switches.
