As opposed to the natural ring of the note it is basically a dead thud which I guess would mean the compressor is really clamping down on an extra hot signal, but that is even with the ratio at ab 9 o’clock or lower. The active signal def drives the Thumbsucker into distortion if the threshold is low.
A liltle late to reply, but wanted to add to...
What JTEX said in post
#339: use a
HPF (something I think every bass player should have right after tuner, in terms of importance).
Also, you could add a pot to your Thumbsucker, between the jack and the circuit-input, to attenuate the signal from your Ray's Active-Pre. You could even put the pot on a toggle or stomper to bypass it when you're playing a bass without a preamp (or switched off your Ray's Pre).
Of course, lowering your bass's volume whenever you engage the ET works in place of the added pot, and doesn't cost you anything extra — if your bass has a volume sweet-spot, then the added pot on the ET-build may still be worthwhile.
Has anybody made the Engineer's Thumb with a side-chain?
Might be worth looking into.
Or DIY your own multi-comp — split the signal and compress the highs and lows separately; start messing with crossovers... I might have to go over to TalkBass and pick FEA's Frank Appleton's brain...
@Robert right on, that's gonna save me a ton of headaches, like this one. Noice!
At this point, I'd definitely use an adapter-board for that 2N5457...
SOT23 Adapter
www.pedalpcb.com
