ColShaner75
Did you happen to find a drill guide for the Microbuffer? I’m needing one too.hey @Robert mind if i get the MicroBuffer drill image and part number/spec for the Neutrik style phone jacks on it?
thanks!
Thanks.
thanks!
Waiting for the build doc for Double Pendulum Harmonic Trem. Its been over a year and I want to troubleshoot my build
Could you, please, share the schematic for the "Basic Relay DPDT Switch (Latching)"? Thanks![]()
can be removed from the wanted list......and Scabbard too?
Hi @Robert just checking if there is an available drill template for the Pastel Preamp. Does it require a specific type of 1/4'" jack to fit properly?
Thanks, apologies, I actually meant the Tayda drill template. I'll figure it out from the document drill templateDrill template is in the build doc. (I know, right!?)
https://docs.pedalpcb.com/project/Pastel-PedalPCB.pdf
I used the standard enclosed type jack, others may fit as well but I can't confirm.
Bump for the MicroBuffer drill guide!Did you happen to find a drill guide for the Microbuffer? I’m needing one too.
Thanks.
any chance you could post the build docs for the Basstortr? pretty please
