Hi All, Just received my first ever order of boards from PedalPCB and was just wondering when the Build Doc for the Salesman Overdrive is going to be posted? I'm sure I could build it without them (I do have the Chili Dog BOM), but it would be easier with them on hand. Thanks!
Thanks, apologies, I actually meant the Tayda drill template. I'll figure it out from the document drill template
Ahhh, that makes sense.
This one isn't verified but should be correct since it's based on the Kliche Mini SE template.
The toggle switches are sized for MTS toggles (6mm), if you plan to use Dailywell or Taiway you might want to increase their diameter.
I'm looking for the schematic for the Dielectric Boost. I'd like to adapt a smaller board like a Je Taime etc to use this circuit in a smaller enclosure like a 1590B. Thank you
