Missing Build Docs / Schematics
Regarding the Paragon - does @Robert or anyone happen to have handy the labels for the bottom I/O holes? E.g., typical PPCB boards are in-gnd-sw-out. But the Paragon is unique and not labeled, and also not in the docs. I’m using my own bypass board for my Paragon build.
taking a stab at it before @Robert corrects me... From the left side....INPUT JACK/CIRCUIT BOARD IN/LED +/CIRCUIT BOARD OUT/GROUND/CIRCUIT BOARD IN (from side 1)/LED +/CIRCUIT BOARD OUT/OUTPUT JACK
No schematic but BOM and template are posted here
Dude!
Yer killin' it! (y)(y)
Such Robust support for Robert, it's like you're his left-hand man, freeing him up to keep making the already-Robust list of PCBs PedalPCB offers even more Robust.
On behalf of the Robust roster of PedalPCB-forum punters and paying patron-lurkers alike, whether they want me to or not, I'm giving a Robust thanks to your positively Robust positivity and Robust help to Robert and fellow forumighty users.
Hi All, Just received my first ever order of boards from PedalPCB and was just wondering when the Build Doc for the Salesman Overdrive is going to be posted? I'm sure I could build it without them (I do have the Chili Dog BOM), but it would be easier with them on hand. Thanks!
Thanks, apologies, I actually meant the Tayda drill template. I'll figure it out from the document drill template
Ahhh, that makes sense.
This one isn't verified but should be correct since it's based on the Kliche Mini SE template.
The toggle switches are sized for MTS toggles (6mm), if you plan to use Dailywell or Taiway you might want to increase their diameter.
