itstimtime
Wired her up, and got nothing. Reflowed solder. I don’t have a DMM because the only issue I usually have with builds is forgetting to check the led cathode/anode
. D1 & D2 are throbbing. I’m getting signal when it’s bypassed. While turning the internal trim, I get slight “pops” in certain spots. Wondering if those scratches on the underside around IC2 could be the culprit? Haven’t tried swapping out chips because I’ve never had an issue with them
I read that a lot while digging through old posts about this build though.
