Looks awesome! How does it compare to the more common BJT treble boosters? Rangemaster, Brian May Booster, Naga Viper and what have you.Runoffgroove Omega. It's a FET based treble booster.
View attachment 93615 View attachment 93616 View attachment 93617
What caused the corrosion just on that one spot, leaky cap?I fixed this dude today for my friend. The cymbals and high hats weren’t working and the toms had a decent hum.
It’s a Korg Rhythm 55 or KR55 drum machine.
It sounds exactly like it looks.
Opened it up and found some corrosion that had affected several joints and grounds. I even replaced an IC that was known to have been a culprit sometimes just in case. Replace a few caps that were in the corrosion and removed as much of the green stuff as I could. I had to make some wire runs to connect where the traces had been obliterated.
Main corrosion in the cymbal/high hat circuit:
Corrosion on ground and input cap:
My repair:
Upper board with new IC10:
Lower board was fine.
I forget what you’re using to shield your I/O wires. Do you find it makes a difference? Well obviously you do, or else you wouldn’t it. Anyway, I need more coffee.
I also like how they locked down the trimmers after they were set. Or variable resistors?
what in tarnation?
If it's stupid but it works, then it's not stupidwhat in tarnation?
I surrenderAnyone that says SMD isn't good for prototyping just isn't determined enough.
If it's stupid but it works, then it's not stupid![]()
