Double Jeopardy Trimpot settings
falco_femoralis
Hi all, I just put together a Double Jeopardy and it's working great. What are the pads below the trim pots for? I'm guessing to bias something? How would I go about setting it up?
Thanks,
Looks like they're labelled 9v
If the voltage at that pad is in that neighborhood, that's what I'd try.
I knew I had seen that somewhere else. This is from a Zoar I did recently. In that case, the pad was labelled 5v, and that's what I set it to. I'm guessing that's something Robert has implemented on the newer boards. Definitely one of those little UX touches I appreciate. Like the pot labels silkscreened on the other side of the board so I don't have to keep flipping it over to check!
^ on my board they are labeled 11.8 and 13.7. How do I read them with a meter? Black lead on ground and red lead on the pad?
