...it's literally just a Ruby clone with some very, very bad design decisions. Rather unsurprisingly the owner said he's had it repaired twice over the last few years and it keeps on breaking. Noticed both the output jacks are very weird - they don't work with any of my mono or stereo 1/4" cables unless they're only 3/4 inserted, and the entire layout/component choices leave a lot to be desired.
Exercising my paradoxical relationship with vocational masochism.
Lots going on here:
I've been experimenting with I/O and using identical control layouts/patterns. I expected to only have 2, 3, or 4 control points, but this one is pushing the 1590B with 6
This box is my proto enclosure, so it has jank and no polish, btw, so it's function all the way down. Thankfully my nephew has a mill and we can work relatively quickly to refine things.
I wanted to see if I could fit my new darling circuit into the B sized box; the Kewpie. I've affectionately called this the KewBie.
I if course had to resort to 1/8W footprint resistors, submini switches, and 9mm pots (more on that later) and it's density is extra thicc, but still doable. I actually did a unique layout for it at first, but it necessitated the switches traveling on the horizontal, which bugged me, so I ended up modifying Robert's, scaling and shuffling where I needed to.
Having kicke mucked about in 3D helped a lot, but for this round I didn't want to take any chances, so I made up a breakout board for the pots. Unfortunately I measured from what I thought was an Alpha pot, but did not match the actual ones I bought. Still, progress.
The board was also a necessity because the tolerance between the pots and the jacks from the I/O was maybe 2mm in CAD (turned out to be barely that in practice). The milling is required to have the pot sit completely flat, clipping excess pin material.
In the end this doesn't need a breakout board… the height of both the switches and the pots will work out perfectly. Just some wasted board area will be required.
Additionally, I experimented with a tighter fit for component vias, and it makes soldering without additional flux ugly looking, as seen on the PCB pics.
But it all works as intended!
PS, before anyone grumbles, I messaged Robert about this.
@Band of Dans — would love to hear the story of why "you're" friend wants a grammatically incorrect pedal...
Oh, and a Discount Editing-Rate for your friend... damn. Now I'll have to offer Aleph Null a discount, too.
Holy shit! That's from almost a year ago and I never noticed it. It doesn't help that you have to convert the text to a graphic so that you can make a hole in the solder mask. Guess I'll add corrected face plates to my next PCB order...
I tweaked my Drone master/rat pedal with IC change. Before IC1 was ca3140 and IC2 had metal can 741, now it’s NOS lm308n in IC1 and ca3140 moved for IC2. But I noticed I’ve played this circuit for a year enclosure shield lead missing from star gnd. Was a quick fix, but imma dum dum…
Edit. and I finally fixed a table saw I got as a freebie. Was missing one bolt for locking table flip and handle switch needed cleaning and lube. Now it’s only missing side guide.
I had a Low tide mini I built a few years back where I stuck a 2.5 centre pin power jack rather than the 2.1 it needed... it also was a bit noisy.
Last night took it to bits, switched the jack, replaced the Jfets (I suspected they were the cause of noise given my dodgy SMD soldering), re-biased (I think) and reset the gate - so much better and so much less noise - it may have been the bias on the BBD was out but it sounds great now - still a bit daft on bass but hey!
