While I was soldering my Q-Tune, I kept thinking I wasn't getting enough solder in some of the pads, but really it was just a trick of the eye — the pads
looked empty 'til I changed my viewing angle and then could see that it wasn't "solder-hungry", just a dark-reflection and that I'd already filled the pad and made the component-pad connection.
Good catch on the possible stray-wire, Jimilee. That definitely looks suspect.
I had trouble seating the MCP6002, but managed to gently
* re-apply it a few times 'til it seated correctly.
*Lest I wreck the socket (highly likely) or bend/break the IC's legs (unlikely but possible with my ham-fists).
I wanted to use what was supplied with the kit, AND I've run out of machined sockets — otherwise I might've replaced the fly-leaf IC-sockets with machined units. I treated those fly-leaf sockets with kid-gloves, as I've had less than stellar experiences with flakey fly-leaf.
So that's my recommendation — check the
fly-leaf sockets
 for broken legs or other malformed maladjusted malignant maladapted malfunctioning malarkey...
