Why cant the tap functions be handled by an independent PIC then the PIC feeds PWM to the FV-1. That will easy the processing load of the FV-1. Honestly everyone is way over charging for Tap functions for the PT2399. PIC programing is easy and Tap function is simple math.The FV-1 code for tap tempo eats up a majority of your instructions that you would use for the actual delay effect..... you can do it, but then you're a bit limited in what you can do in terms of the actual effect. The Daydream would be an absolute no go, unfortunately.
I do have plans for a tap tempo module for the FV-1, but it's been on the back burner for some time now... eventually......
