Danbieranowski
Hey all,
I’ve wanted to put together a reverb and delay combo pedal for a bit, but I wanted them to run off a single footswitch in series (delay into reverb). I worked out my expected wiring and confirmed with @PedalPCB to make sure I had it dialed in. Put it together today and loved the results (thank you Pythagoras). I knew I wanted to add a little sustain functionality or something else fun, so after a suggestion from @zgrav to feed the output back into the input, I came up with the delay and reverb out being fed back into the delay input for feedback mayhem.
I’m including an image below that explains the wiring routing in case anyone wants to build something similar.
Here’s what it looks like on the outside:
Here’s what it looks like on the inside:
Here’s what it sounds like:
And here’s the wiring:
