Sheepylove KiCad library
This is great, thanks!
I've been looking into how to create a personal KiCAD library, any recommendations on getting started?
Honestly, just take someone else's..
But if you want your own, define what your standards are. What size resistors, caps, diodes, etc. Then create the basic set. Everything which is uncommon (like relays, or LDRs) will pop up when you need it. Then you do those.
I am really new with JLCPCB and using EasyEDA. How do I download your JLCPCB library and import it to EasyEDA?
From what I can see, EasyEDA is looking for .json file to import.
Thanks for making this available!
Sorry. I’m not sure about other applications, I work in KiCad.
These are awesome. I have done a few layouts with them already. Lots of options in these libraries as well. Thanks for sharing.You have saved me a lot of work not having to create my own. Mine was a hodge podge of things
I had made and beans etc…. No real standardizing on my part. Anything I make going forward I will try and incorporate with these as a model.
If anyone was using this, there was a mistake in a SMD footprint which I’ve fixed.
I’ve also synced my work process to use this library instead of copying my working version so it’ll be updated more often.
