Nobelium - tube bass preamp project
@vigilante398
I thought I remembered seeing this info somewhere but I looked everywhere I could think of and didn’t see it. What frequency (roughly) does the treble control start affecting? Seems like somewhere down in the 4-5k range? Is there a spot I could try changing values to try getting that up a little higher? I find it’s just pulling a hair too much of the mids up with it. I thought if it was as easy as swapping out a resistor or two I might give it a whirl.
Thanks!
@vigilante398
Thanks!
The Noble/Nobelium uses a Fender-style tonestack with a fixed mids response. It's a shelving filter with no fixed frequencies, and the controls are very interactive.
That being said, you could try increasing the value of the 270pF cap in the tonsetack to something like 470pF or 500pF, that should tame the highs a bit.
@vigilante398
That would be extraordinarily high as a starting point. By maybe an octave or two, at least. ;)
Check it in the TSC calculator first so you can see whats happening, remember to leave the Mid pot on 10 as the Nobelium uses R21 instead of a Mid pot.
Just click on "Edit" and change values and then click "Apply" and then you can slide the Bass and Treble pots to see what happens, you can also change the R21 resistance but keep the "Mid" pot slider on 10 since it is a fixed resistor.
Here is the link to the TSC already set for the Nobeliums tone stack: https://www.guitarscience.net/tsc/f...C3=100n&RB_pot=LogA&RM_pot=Linear&RT_pot=LogA
I just noticed that it looks like the 1/4" output seems wired in reverse, the signal is wired to the shield ring and the ground is wired to the tip on the socket.
If the 1/4" out works the socket must be insulated from the box by the powder coating only, it would be best if the wires were reversed to the correct position.
I must have looked at the picture lots of times and not noticed until now.
Cheers
Mick
You noticed right.
I already sell the nobelium to my friend and I noticed it while testing. It’s already changed.
There are drill guides and art work for all the C2CE projects on the C2CE webpage, there is white artwork for dark boxes and black artwork for light boxes.
I get them made at Tayda since they can drill and apply the artwork to any box they sell.
You’re the best. Thank you! Got it all boxed up but not getting any output 🤕 now begins the process of troubleshooting
I am getting a very high pitched squeal from mine. It’s fairly quiet but becomes noticeable when the preamp gets gained up. Does anyone else have this noise? Any ideas what could be causing it?
Thanks
