Feral Feline
@FF
Determine which side is pin one.10k resistor from all other pins to pin 1. I would solder them standing up, unsoldered lead to the sky, then solder a piece of solid core to pin 1, bend it at 90 and bend the R leads over it at >90. Put a alligator clip on the wire near pin 1 as a heat sink, then solder the resistors.
Pin 1 likely goes to ground, vcc or vref(or v+/v-/ground)
I can't read your black text so sorry if I missed something.
JWIN615 FOR THE WIN!
That would then match up with the pic I found online.
Indeed, I wanted to explore the far ends and see what else they connected to (gnd vcc vref as you noted).
Looking at other builds' gutshots, nothing on the part nor on the PCB (no square pad, all pads equally round) to indicate a direction as to how it should be inserted.
Might try and borrow the DMM I gave away, I'd feel more confident about finding which end is "up" if I could have beepy-flashy than just reading "000".
RE "black text" — hmm... I only changed colour to pinkish-purple on one word, "pink" in the sentence "See the PINK one, #3?". So I don't think you missed anything.
The graphic you posted helps my mind tremendously, thank you.
The PCB has 8 pins vs the graphic's 11, but it pretty much confirms what I thought, that one end has to be the "common".
I'll get to this again later today.
Merci beaucoup!
