iamjackslackof
Howdy esteemed forumites!
I am planning on jumping back into laying out my own PCBs, specifically an all-in-one Jimmy Page kinda pedal, which will include an EP-3 preamp clone, delays, Phase 90, etc. I am hoping to replace my Chase Tone Secret and Clinch EP-PRE and several delays with it, and as a hopefully permanent board pedal, I want to reduce as much as possible.
To begin I will only work on the EP-3. I'll probably just use Robert's schematic, but since I have full control over the PCB and parts, I can hopefully bring the noise down as much as is practical.
Initially I am only concerned about noise from components, lead dress, assembly, etc. I'll worry about the PCB design and layout noise side of thing later.
Long-ass preamble to my question done, my question is, what are my options for reducing noise, if money is no obstacle?
I know a few things already, like quality parts, shielded cable runs, etc. My plan is to use high quality Dale resistors. I don't mean money is no obstacle completely literally, but for a one-off pedal that I plan on using for a long time, so I will spring for Dales and other fancy parts if they make an appreciable difference in noise. I'm have a Cioks DC7 and a Walrus Audio Canvas for high quality, hopefully quiet power.
Specific questions:
Thanks everyone!!
EDIT: Jimmy briefly used a Univox Unidrive, which I built the AionFX version of, but I found it too noisy. I'd love to take anything I learn from this thread and apply it to that circuit as well!
Specific questions:
- My understanding is Johnson noise is less in larger wattage resistors, so should I use 1/2 or even full watt resistors?
- Lower values resistors have less noise too as I understand it, should I look at tweaking some EP-3 component values (like voltage dividers maybe?) to reduce resistance wherever it makes sense and won't change the circuit operation?
- Is there a better option than Dale? I was looking at the CMF60 line I believe.
- What caps should I use?
- I always use nice Nichicon audio electros in my builds already, should I use film or some other fancy material?
- Will swapping electros outside the signal path to a different material matter at all?
- Is there a material for signal path caps that is best for low noise?
- How can I get the lowest noise from the charge pump?
- Should I audition the TC1044SCPA?
- Maybe use a different charge pump IC altogether?
- What about noise in the power filter section?
- The EP-3 does some less-common stuff with diodes, can the diodes be optimized for noise?
- Will adding more filtering help? Maybe a breakout board to add more caps or something
- The 2N5457 already needs to be within pretty specific parameters, should I audition those for noise too?
- Would auditioning pots or any other parts help?
- Perhaps most importantly, how can I measure noise, so I know my mods are helping? Do I need a 'scope or something?
Thanks everyone!!
