PPCB Dark Rift
GrAmSou
Hi everyone,
Hope to be in the right place, for this kind of question.
I just fnished to build the Dark Rift (EQD Space Spiral clone) and it doesn't work.
Additionnal information, I bought a ready to soldering kit on Musikding (my second one).
Bypass is OK, but that's all.
No sound, and even the LED doesn't want to light up.
I only made one change, as I put a 10Kohm instead of the 4K7ohm for DEL, to reduce luminesence.
Here is the result :
IMG20260328165504.jpg What can I check ?
And last but not least, I'm a real beginner/noob (put the word you want), only equipped with a soldering iron and a multimeter.
Solution
I had to go through 3 different PT2399s before getting a good one. I don't know if that's your issue but it was mine. I think they are known for being lousy.
Thanks for your feedback, tried to replace to, but the culprit was the LM324N.
Replaced it and *tadam* my pedal was alive.
1) make sure you don't have you guitar plugged into the out. Easy to do w the pedal upside down
2)make sure IC in to right is fully seated
3) some of the joints on the 3pdt are questionable. I would slowly reflow and add a bit more solder. Make sure you give it time to cool between reflowing or you may melt the internals.
Thanks for your time.
I re-seated the LM833, and reflowed the 3PDT.
Still nothing.
Stupid question, but can a deffective DEL may prevent a pedal to work ?
'cause this DEL is from a cheap set found on Amazon (Allecin' brand).
A led shorted to the enclosure could cause issues
Measure DC voltage at these pins with the pedal powered and post results(black probe to ground, red to each pin)
LM324A at point 4 : 8.99V
LM833M at point 8 : 8.98V
TL072 at point 8 : 8.99V
The LED may not be shorted. Locked in its plastic clip, and welded straight to the PCB.
Ok. You're not shorting and power, at a glance, looks good.
If you have put together an audio probe, you should check inputs and outputs of the opamps. This is a quick way to narrow in on what part of the circuit you're losing signal at.
If you don't have an audio probe, I'd check the values of your resistors. If you can't count bands well, use a build report that has the same rev of your board and good clear gut shots.
Like this one
I'd also make sure you don't have any wires going from the pcb to the footswitch board that are shorting.
I see you have pot condoms on the upper pots so I assume you have them on the lower pots too.
If not, that's an issue.
I check all the resistors.
Most of the 47K are litteraly out of range. Between 13K and 35K :eek:
A 1M is around 700K and a 22K measured at 18K (maybe this one is acceptable ?).
As I have some resistors from a set (checked OK), I'll replace them.
Can I check capacitors and diodes with my basic multimeter ?
Again, thanks for all your advices and your time.
EDIT : yes, all pots have caps
OK, so I reworked my switch soldering. Replaced the wires between the main pcb and the switch's pcb to avoid false contact.
Still no LED, BUT ! When I re-checked my pedal, this time, I was on my knees in front of my speaker.
And heard something, coming from another galaxy (at least) a really (really!) tiny modulation in the back of the sound.
So, activated or not, the clean sound is OK.
When activated : no LED, clean sound fully passes, and with pots at full-range I can hear a slight modulation of the noise floor.
