- Build Rating
- 5.00 star(s)
I had no issues with the boards/parts list. Works great. I would say it's recommended use is as a presence and depth control for amps that don't have one or like a low and high freq shelf eq. (Aka slam mode for the metal guys ;D)
Some random tips and things I learned from building this recent bunch of pedals:
Get your tl072's from ppcb cuz they are cheaper than tayda for example. So many boards use them.
The sand texture tayda enclosures are like phase 90s. Seems like a nice and durable coating.
Edit: it might not be Daisywell switches fault, might be my amps fx loop instead.
Dailywell switches pop loudly (and have a weird click so I don't recommend wasting your money by paying extra for those. Good thing I bought a mix of different ones to try out. The click happens right at the bottom of the range and is very firm which theoretically is good if it weren't for the pop. Also withstands plenty of heat while soldering the breakout board to it etc.. (still needs a break cuz it gets warm, but the pins don't get loose and then the switch is wasted like the cheap blues can for example)
