Thks, I've searched their site, its not there. Old links to it do not work either.Effects Layouts has one in a 125B enclosure called the "Mitt."
Yes, you got the first part right.That brings me to ask one of those "afraid to ask" questions / subjects. Eagle is a software to create PBC designs? Then the created files are used to fabricate PCBs at places like JLCPCB? What is a "lard?"
Maybe this is the same thing but what is one to do with this kind of thing on the Effects Layouts Blog section like this:
Aclam The Mocker
Here's the Mocker. It's a recreation of the on-board fuzz from the Vox UL730, used by the Beatles on Revolver and a bit on Sgt. Peppers. It'...effectslayouts.blogspot.com
Thank you for that.Yes, you got the first part right.
The layouts on the left are for perfboard, you basically create the connections with solder (or wire I guess) as shown on the image. Google perfboard and it will make sense. The bottom right is for etching your own PCB at home, I don't know the details but I think you basically transfer that mask (the black part) onto the PCB stock and then etch away the white parts with acid.
