Fama
Dual-EEPROM (toggle switch) plus dry/wet stereo modded Arachnid, finally complete. Surprisingly painless, I had some issues after boxing because the stereo ring wire had a cold solder joint (well, more like just a shit solder joint) and I didn't understand how the EEPROM switching works (you need to move the rotary switch too so it loads the new program), but once I figured those out it worked just fine.
Obviously it's more of a studio toy than anything for live use just from the form factor, but the EEPROM daughterboard is also just going into the socket for the original EEPROM (I would have soldered the wires in but it already had a socket from earlier, my mistake) which is kind of scuffed. I think they will hold fine, but maybe I could try soldering the wires into the socket itself - desoldering the socket feels annoying.
I was kinda dreading this for a while because of the extra added complexity, but going carefully step by step and double checking everything helps avoid mistakes.
I was thinking I would put together a "manual" I can view on my phone, putting it in Drive or something and printing a small QR code that leads to it, which I can tape to the side or something. Lots of different programs that do different things.
