New Pedal Releases
What is that even? There's no branding of any kind, that's weird.
$349.99
THE KingTone VINTAGE FUZZ PEDAL
Possibly The Best Fuzz Pedal Ever Made.
  • 2 of the Best Sounding and Performing Vintage Germanium Transistors (MP10b)
  • 2 Classic BC108 Silicon Transistors
  • Ge/Si Switchable
  • True Bypass
  • External Bias Adjustment Allows For Easy Tonal or Temperature Refinement.
  • Hand Wired with Carefully Selected Components
  • Internal Switches for Vintage/Fat – Bass Response.
  • Internal Switches for Vintage/Boost – Output Levels.
  • Fat Fat, did I say ‘Fat’ Tone!
  • Top Mounted Jack Sockets
  • Runs on Standard 9 Volt Battery or Standard Center Negative DC Jack Socket.
  • 9v DC Input has Battery Simulator – The Pedal Sounds Great Even When Using 9v DC Power. (Can be switched off)
  • Internal Switch Allows the Pedal to Run Efficiently on an External Battery Box.
  • Built To Last A Lifetime
  • 30 Day Money Back Guarantee
  • Limited Edition.
The KingTone Vintage Fuzz is a handcrafted powerhouse built for players who demand authentic vintage tone with modern flexibility. Loaded with two vintage Germanium and two classic BC108 Silicon transistors, this pedal gives you the best of both worlds—instantly switchable between warm, rich germanium fuzz and aggressive, cutting silicon bite. Dial in your perfect sound with external bias control for real-time tonal shaping and temperature compensation, plus internal voicing switches to tailor bass response and output level. Whether you crave that saggy vintage wool or a tighter, boosted wall of fuzz, it’s all inside—fat, fat tone included.
is this the Ian Thornley pedal? Don't get me wrong, love me some Big Wreck but I'd be shocked if I'm invested more than the cost of a CD into my fandom even having seen them live back in 98 at Oz Fest
Yeah it is, he rules…but watching the demos it looks like you can’t run the octave side and the fuzz side at the same time. Huge L.
$619.00
THE KingTone VINTAGE FUZZ PEDAL.. Possibly The Best Fuzz Pedal Ever Made.
  • Ge/Si Switchable
  • True Bypass
  • Limited Edition.
$349.99
  • Ge/Si Switchable
  • True Bypass
  • Limited Edition.
I think they misspelled PHAT TOAN
WHat are we thinking the battery simulator is?
The CompanDrive 65 is a faithful recreation of the legendary companding circuit found on virtually every studio tape recording since the introduction of the first Dolby noise reduction process in 1965. This all-analog SoloDallas design captures the elusive studio magic heard on countless classic recordings.
At its core, the signal path is carefully recreated and optimized: the guitar first passes through the Vintage Console Gain Circuit which utilizes the famed LM308 op-amp, then into the 65 Compressor, followed by the 65 Expander, and finally through our Vintage OpAmp Boost. Together, these perfectly balanced stages comprise a secret recipe of warmth, harmonics and dynamics, producing that immediately familiar je ne sais quoi from the golden era of recording.
From the moment you click it on, the CompanDrive 65 reveals itself as a missing link—unlocking a wide range of inspiring, mix-ready studio guitar tones with depth, clarity, and musical feel.
Signal Path Breakdown​
Vintage Console Gain Circuit (VCGC)
Produces rich, hi-fi overdrive with abundant harmonics while subtly shaping frequencies to add fullness, presence, and clarity in the mix.
65 Compressor
Delivers a smooth, blooming soft-knee attack that enhances note separation and adds musical harmonic clipping without choking dynamics.
65 Expander
Restores overall signal amplitude, removing unwanted “pump and squish” while further emphasizing the harmonics generated by the VCGC and compressor stages.
Vintage OpAmp Boost
A classic op-amp design that preserves delicate frequencies and maintains clarity as output level is increased, making the CompanDrive 65 equally at home on a pedalboard or in the studio.
65 Compressor
65 Expander
Vintage OpAmp Boost
435View attachment 115350435 euro.............
This falls kind of short IMO. Like Nostra mentioned, only one side can be used at a time. It’s like if you took a double muffin, made one side octavey, and replaced the toggle with a footswitch. And use relays for the footswitches to toggle them via MIDI.
Analog gain pedals with MIDI are few and far between, so that’s cool. But they could have done so much more. I bought a used Discovery delay, and every single parameter has a CC control. I’ll give them credit for 128 PC presets, but literally all it does is toggle the footswitches.
There’s room for another set of TS jacks at the top. It could be a true dual pedal with series/parallel options, able to patch into independent locations in a pedal chain.
But then again, maybe that’s more functionality than anyone cares about for a fuzz.
