Not sure what those turned out to be in that thread.Correction to what I said yesterday... I do not believe the transistors were sanded after all. I think maybe the primer etched the face of the transistor slightly and made the part number harder to see.
The 2N5551 hits 150s all day, easily gotten from Tayda as well.The transistors used in the original Bosstone had a nominal hFE of around 135. This is lower than the
typical 2N3904, but right in the sweet spot for the 2N3903.
2x NPN?2N3903.
I'll have some in stock by the time the PCB is available.
2x NPN?
Yeah some of the early Alahabra cali, pre shobud, builds had 2xMPS6513, 2N3397/MPS6513"California" Bosstone
I swear I bought a load of them from Circuit Specialists, but I'm only seeing the 6512 which are a bracket lower in gain, 80–100.MPS6513
Used 2n5551 in my Overcast build and they both hit 127hfe. The 2n3903 I had were all around 200hfe.Not sure what those turned out to be in that thread.
Aion mentions in the Oberon (Bosstone) doc:
I’ve got a question, and perhaps I’m missing something, but how does the circuit work with +v jumped to Ground?here's some pics of my build completed in a Hammond 1590B2:
This is it.Correct me if I'm wrong @johnk_10, but I believe he drills out unused pads and uses them for stress relief.
The wire is just passing through the board, not actually making an electrical connection to the GND pad.
Ok. Thank you Robert. That is a choice I guess. But now my question is, what stress can that wire possibly be subjected to inside a metal box with no moving parts?!Correct me if I'm wrong @johnk_10, but I believe he drills out unused pads and uses them for stress relief.
my guess is it relieves stress for the builder, more so than the wiring.But now my question is, what stress can that wire possibly be subjected to inside a metal box with no moving parts?!
That is probably the answer that will make me stop asking why on this one. Thank you.my guess is it relieves stress for the builder, more so than the wiring.
my bad.That is probably the answer that will make me stop asking why on this one. Thank you.
For a one sided etched board with stranded wire I absolutely can see the benefit.my bad.
it's a fair question though.
marshall did it all over their boards
the benefit?
other than reinforcement,
- perhaps helps keep the wires pushed against the chassis (for less noise?) rather than flying around vertically..
- durability for future maintenance?
i wouldn't say it's necessary, but not entirely redundant
