SOLVED SOFTii Overdrive squeeling
Putrid Electronics
Was working fine when I last used it and now it squeels in stoner mode and is making some wild noises. Any suggestions?
Would post a video but it won't let me
For reference it's a M800 and the SFT in parallel. Was not having this issue previously until I installed the LEDs for each. Don't know why that would make any difference
Show us its insides!
SORRY THOUGHT I DID! I removed a ground jumping from SFT to JCM thinking it was maybe in a grounding loop but no change.
For context this was all working fine until I wired the LEDs. I did wire the SFT backwards with the LED at forst but that shouldn't cause this issue. Issue just stopped on the stones setting. I am totally in the weeds trying to figure this one out. I do have input buffer and active blender of needed
Assuming nothing else was changed, try moving the wiring around.
The output of the M800 is running under the SOFTii PCB and awfully close to it's own input wire... this could be part of the issue.
The output of the M800 is running under the SOFTii PCl and awfully close to it's own input wire... this could be part of the issue.
I actually just moved the wires to make it easier to see the board. This is how everything usually sits. Could it be a transistor?
Also want to say thanks for doing what you do. You have allowed me a self sustaining hobby that has allowed me to meet some really cool people in the process.
I would think it would not want to work on both settings. It's only the high gain setting that squeels like it's being shorted. Maybe the switch went?
Still having the same issues with it. I'm to the point I almost want to hardwire it in low gain mode since the customer won't even be using the high gain the JCM side is for that layered over the clean
So I can get the issue to go away by turning down the SFT preamp gain and volume. Now the other issue I have come across is the M800 side wants to almost self oscillate with the volume and gain up the whole way. Is this just too much gain all around? I do have an active blend you sent me that I can try? I don't think it would make a difference though. It really seems like a power issue somewhere
It is a good but of gain combined.
Inputs crossing outputs.
If it was me, I would try each circuit independently. I'd also probably use shielded wire and or route all the wire away from the pcbs and the ins and outs away from each other. Crosstalk izabish.
That was my plan for tomorrow is disassemble and retest independently then if that works. I know the shielding is the issue. I would think they gain wouldn't be as big of an issue running in parallel but I am not engineer either haha
I would definitely reroute those wires. Even if it doesn’t fix it, it’s good practice to remember for later. IE: the input at the switch is on the left side of the board, run it on the left side of the board up to the jack and vice versa for the outputs on the right side. Avoid crossing ins and outs, shorten up the wiring where you can, none of the wiring should be twisted up in any other wire. There’s enough room in the box to do it! As far as the parallel thing goes both circuits are still active regardless of where the blend is set.
I'll start there tonight after isolating the SVT
So I pulled the SVT side. Works absolutely fine and sounds killer by itself. I even isolated the power from each and still same issues. The JCM still works totally fine.
It basically sounds like on low gain that it starts acting like a tremolo as you turn the gain up. Then in high gain setting its just a bunch of high frequency feedback as the gain and volume get up past noon.
Will it self oscilate or does it only do so when playing? If it self oscilates, will it do so when the input is shorted to ground.
Maybe try moving the wires some more, including the LED as it's butting against the led wires., since this started when they went in. Maybe there's crosstalk getting into the DC.
The tremelo remark is interesting.
Have you probed the board to see where it is oscillating, or is it the entire circuit?
It only does it once it is mounted in the box hooked up in parallel the JCM side. It only self oscillated/tremolo effect on the low gain setting and the high gain setting is like a high frequency squeel that changed pitch as you turn knobs. I am truly stumped on this one
