I'm still trying to translate the . . .DPDT Transistor-Swapper
In this case both emitters are going to ground so they don't need to be swapped out, just the Bases and Collectors.
If you've got a circuit that the emitter doesn't go to ground you can still swap out two transistors: add a pole to the switch,
ie make it a 3PDT ON-ON and add the emitters to the switcherooniki.
Plenty of examples online of switching out two transistors, this is mine.
BTW, that's not gibberish in the diagram, that's top-secret code.
(see if you can decipher what it says!)
Fair enough!Okay, even the cryptogram books give you a hint to get you started ...
The first line says "DPDT"
21 different clipping diodes....My dudes...
This thing calls for a challenge.
Hang on, gonna hit the snooze button just for a minute longer...My dudes...
Gimme some time to figure out the most chaotic way to implement this. Right now I’m thinking pickup selector that just has the same 3 options over and over againMy dudes...
21 different boxes, 1 effect21 different effects, in one box.
OD is glorious, is that you?21 different boxes, 1 effect
