hahaha that is literally the best compliment I could imagine thank you!I think Tayda owes you some advertising dues- those all look spectacular!
I tried some from small bear, and they look and feel great..... also wondering if those are the LMS 'Brutalist' plastic knobs on there and how you are liking them in person? Looking great on photo!
Like these here:
https://lovemyswitches.com/brutalist-knob-18mm-od/
Like these here:
Thanks for quick reply! I see what you mean that the height can block the view to see text on pedal. At the same time I like knobs that go right down pretty close to enclosure with a standard 6.3mm pot shft, rather than hovering above the enclosure when the knob is a low height.
So do these go down pretty close to enclosure and do fit generally pretty well, are they pretty much consitently on axis or do they gice a bit of a slight wobble when turning pot?
Cheers!
Cheers, yes I've been good and busy not too much time lately for building but getting back into it again.Hey cooder how you been? I recently started using affinity to get with the times, I had been using paint.net still haha. I tried adobe illustrator but affinity is much more user friendly and way cheaper. Within a couple days I had it figured out. And pandemic pedals has a great walkthrough tutorial for tayda and some great templates to download. Highly recommended!
Nah I use Illustrator. The Tayda UV Printing Thread is worth checking out if you haven't already, a lot of people in there use Affinity.Also wondering, have you used Affinity Designer to create the files for Tayda? Cheers.
